block | 04-26-2012 | comment profile send pm notify |
34m omnex remote that I can't get the red light to stop flashing and the green light doesn't come on at all. The batteries are charged Any suggestions? |
mrpumpy | 04-26-2012 | reply profile send pm notify |
emergency-button will probably be stuck inside the button itself |
gavros | 04-27-2012 | reply profile send pm notify |
Does shook it somewhere? I dont know about omnex but about tele right that mpumpy says. |
Dont need one | 04-27-2012 | reply profile send pm notify |
I cant believe you havn't had more responses. Check all of the above, check all plugs to PC boards, switchs and battery conections, on battery to, Pry battery conections out with screw driver, if this dosn't work call me and I will get you fixed with best mechanic in US. 303-472-5838. |
gavros | 04-28-2012 | reply profile send pm notify |
2 times I have the same problem, the red light dont stop flashing 2 times I change the emergency button. the red mushroom |
Many | 04-28-2012 | reply profile send pm notify |
A good test is to try your hardwire remote and see if problem goes away.Also wise to check all e-stops for faulty switch or moisture (water) which can get past seal. |
forgot to mention the hopper grate switch will do the same thing.these are vary common areas |
xforce1 | 04-29-2012 | reply profile send pm notify |
Check your switch on the back of the cradle. Its the switch you use to turn power off as far as the pump so you can change your mud cups. If your red light is flashing slow, I bet that is your problem. Its got bumped maybe. |
dlee7729 | 04-30-2012 | reply profile send pm notify |
Hey guys don't kill me for this coment. " Why don't owners and operators call the factory first for problems " . |
Vasa | 04-30-2012 | reply profile send pm notify |
I won't kill You . I call our dealer and they answer 24/7 , if We have long pour they use to have some mechanich that come to the site . PM-Nordic ! Verry good dealer of Putz in Sweden and Norway . |
