Sensors in concrete pipeline
abdul 06-24-2011
Any suppliers of pressure, temperature, sensors which could be fitted in a 125mm pipeline for long distance concrete pumping. Please let me know if you know any suppliers who supply these sensors, I want to use sensors for high rise and long distance concrete pumping.
Many 06-25-2011
Yeah,called the pump pressure gauge,works every time.
dlee7729 06-25-2011
Like many said. Its all in the pump pressure gauge. Tells you what the pump is working at and also a great tool for estimating slump when going threw line pipe. For example lightwiegth concrete. Today I pumped lightweigth threw 200' of pipe and 5-5" hoses. I took a few pressure readings off the gauge on the frist trucks and got in nailed in at 2000 psi for a 6 " slump on deck.
abdul 08-07-2013
Thanks
