Sermac Remote set up. 37m Z
ZO 02-16-2011
How do you set up the booms speeds on the cordless remote?
Thanks ZO
rick5z 02-16-2011
call rick burnt from sermac, he'll be able to explain, I've done it but can't remember the process...here's his #763-772-6732
ZO 02-16-2011
Rick is out of country have not spoke to him in over month or two. Pretty sure that Sermac America is on its way out. DOes anyone have contact info for anyone else that could help?
any pump 2 02-16-2011
try www.utranazz.com there uk sermac dealer
murf 02-17-2011
As you move the section/ function at the speed you require  hold the speed button on the lefthand side of the remote, this will set it at that speed .
rick5z 02-17-2011
yes murf but you have to do something to the reciever inside the cab first to take it into program mode
Sir Mac 02-17-2011
ZO I sent you a pm
murf 02-17-2011
rick- what remote u running? we have autec unit and never touched it?
rick5z 02-17-2011
mine is a autec also, with my pump you must unplug reciever inside of cab then remove cover and flip a switch then re-plug reciever then you can program remote
