| TooTall | 10-02-2012 | comment profile send pm notify |
Check this guy out. Both front outriggers are swung Out but not extended. 1min: 18sec... Makes you wonder if he's even aware that they actually Extend on his 44 TurbO???
| local 12 | 10-02-2012 | reply profile send pm notify |
no way 1 truck at a time 10 hours pump time! |
| lucky phil | 10-02-2012 | reply profile send pm notify |
Unless that slab is 10 metres deep im thinking 710 metres is a little bit to much crete! |
| PUMBO | 10-03-2012 | reply profile send pm notify |
What he is doing has some logic behind it. If first and second arm on that boom is vertical the tipping forces are less than fully extended. Furthermore, arm 1 and 2 may act as ballast for the machine and its tipping point is pushed somewhere closer to the centre of machine. Putzmeister tried this with Ergonic flexible support. But for some reason the idea was canned. www.teksindo.com/pdf/Putzmeister/EFS.pdf |
| Travelteck | 10-03-2012 | reply profile send pm notify |
The short rigging is a obvious one, but I am suprised no one comented on the open water box, no cover at all. I see this on a lot of units. Guys keep them covered up please. I would have to ask if this vintage had a cover but everything now is suposed to, dont use this as a good example. |
| jaybee | 10-03-2012 | reply profile send pm notify |
Hey come on Traveltec, DON'T LIFT THE HOPPER GRID! is logical DON'T PUT HANDS INTO AGITATOR! makes sense also! BUT put lid on water box ..... OK should be ...... but why make such a big issue out of that? Problem with PMs, JJs etc is that they sometimes shortstroke/longstroke, becoz of stupid limit switches. I love my Schwings with their hyd signals!
| ShortStik | 10-03-2012 | reply profile send pm notify |
saw way too much to even start---my head hurts |
| Doug | 10-04-2012 | reply profile send pm notify |
Covering the water box is a safety issue and a response to lawsuits brought by people who knew better but still don't want to held accountable for their own actions. This is not a Putz or Schwing issue. |
| Travelteck | 10-04-2012 | reply profile send pm notify |
Jaybee, You are correct no one is supposed to be on the deck but there was a guy with a video camera walking around the deck while pumping, I have had Inspectors, Laborers, Pump company assistants, Contractors Union BA’s all at some time wind up on the deck even when they are not supposed to. The issue is Accidents happen, there are hazards on decks, Hoses Buckets and general pumping supplies, this on all brands of pump. All modern Mfg’s of pumps think this is important enough to mount covers, regardless of how they stroke. I only pointed it out to raise awareness to the potential for accidents to happen, young or old, Green Horn or Veteran, Putz or Schwing all live with Gravity. |
| pink panther | 10-05-2012 | reply profile send pm notify |
The only way he could get that many yards done in that time is to stop the clock after each load. Besides that, which is not important. There are even more safety issues. There is no type of barricading set up around the pump on that busy street. Even a couple cones goes a long way. Plus add some caution tape around the pump. Also, with the pump shaking on every stroke, all the cribbing piled up can fall off the pump and into traffic and cause a major accident. |
| SUPERDOFFER | 10-06-2012 | reply profile send pm notify |
The bad part of the story is that there is enough room to do the short rigging the right way. And talking about the waterbox. A little bit more water please. |
| Beast | 10-10-2012 | reply profile send pm notify |
If you have ever seen a guy lose a foot, break a leg, due to no cover on water box , it would be a big deal |
