slow boom
PDe8291938 05-20-2005
is there anyone out there that knows how to speed the boom on a 32xl scwing up?
I am thinking someone out there, should know something
there is no computer on board this unit
Hastings 05-20-2005
What is the Bar pressure guage reading when you dead head a cylinder?Jamie
300 bar
Bob 05-24-2005
There are lots of possible problems. Alll things being equal I would see how much oil my A2F-? was putting out at pressure
PDe8291938 05-25-2005
thanks so much for all of your help. when I am done I will let you know how it all works out, or ask another question.
DAVEtinkle 05-27-2005
To check your boom pump output after pumping a job so everything is warm. than dead head your outrigger system with full rpms and gradually reduce the rpms to 0, If you have signifcant drop in boom pressure than your pump is week.If that is the case be sure and change the coupling also.
ted 05-31-2005
Try the boom pressure valve as the nylon washers some times crack.Boom oil filter.Have the boom pump tested.Hope this helps. ;p
