Slow setting up
biged 10-08-2011
Guys my  1989 32 meter PUZT doesn't get used much so today I decided to set it up so I cranked it up built up my air, then set the riggers while doing that I noticed they where moving very slow, I wondered maybe my filterers needed changing, I thought I was in 7th gear, tomorrow I will check it to be sure hopefully that was my problem, I crank it up about two times a week, if I don't start it for a couple of week its really hard to crank.
Travelteck 11-25-2011
Biged
I think you are on the right track with the gear selected, I think you might have been in low range.
If the suction filters were plugged you would have heard pump noise, you can look at the filter gauges to confirm that they are in the green.
Did you try to stroke the pump? If you were in the wrong gear it also shouldnt stroke.
Give me a call and we could talk more about it
360 600 5695
biged 11-25-2011
That was what happen its just fine now thanks.
BRETTSKI 10-11-2011
I run the samething 1992 32m Putz swing out front outriggers, all four move very slow, all I do is bump up the rpm little bit on the truck and they fly into position.
