Small boom / Squeeze pump
Redman1 07-10-2008
I am starting to see a need for a very small boom. I have looked at a few squeeze pumps. I don't know how a squeeze works, could someone inform me. I am looking for a small boom, 14-23 meter with a compact design, low unfolding height... maybe a z boom?
desertrat 07-10-2008
they work by the rollers in the drum squezzing the concrete forward as the roller assb. rotates around the centershaft. the ones i ran had two rollers
the drum is under vaccum so it pulls the pumptube back out thus sucking more concrete into the pump
the tubes used to wear out quickly and when you reversed the pump they tubes would collapse and lose vacum so no suction in reverse. i ran these in the early 80s so some of those issues maybe worked out. they hated rocky mixes and waterwash only kind of pump. i remember one hot august in marco island fla. when the pump tube blew while pumping planters through a standpipe 18 floors up worked so hard cleaning the drum and retubing i threw up lol
Todd 07-10-2008
http://www.usedconcretepumps.com/pump_detail.cfm?pumpId=3850
b-alto 07-10-2008
Buy a 28 meter.Their money makers. Talk to Fred. Any smaller is too small.
Kiwi pumper 07-11-2008
Hi Redman1
We run a 14m and a 29m squeese pumps both 3 stage and i have just order a 26m 4 stage, they work well on a round stone the concrete is best if its min 120mm, 5" slump but it will pump dryer, they don't like line pumping much about 50m rubber hose is about the most we have had to put on the are very smooth pump, our pumps are about 90s models the 26 and 29 are empty a 5m3 truck comfortably 6min and smal one 8-10min , the round stone we have the tubes last about 5-7000m3 and the sharp stone which is in other places in NZ the tubes only last 3-4000m3,
There are lots of tricks to operating any pump as all you guys know, these are pretty simple and we have had up to 3 concrete trucks backed into hours and done up to 200m3 in a day
I will try and load a photo or two
eddriego 07-11-2008
Redman I own a ITC 14 M SQUEEZEPUMP IS CURRENTLY POST IN USED CONCRETE PUMP WEB SITE. I AM SELLING THIS PUMP , IF YOU NEED PICTURES CALL ME 787-464-4398. MY EMAIL IS PUMPINGGROUP@YAHOO.COM EDUARDO RIEGO
eddriego 07-11-2008
MY IS 97 DON'T USED VACUUM HAVE IS IN PERFECT WORKING CONDITION NO LEAKS AT ALL AND VERY ECONOMIC IN DIESEL
eddriego 07-11-2008
http://www.usedconcretepumps.com/pump_detail.cfm?pumpId=4004
Bob 07-11-2008
They sure limit the material that you can pump
65m Petee 07-13-2008
schwing 31 EZ is a great small boom.  takes a little time to get use to but you can get 31 meters of stick while unfolding under 19 feet.
Ry 07-13-2008
Redman
I have a 21-22 meter Schwing for sale if you are interested give me an email.
rvanderlugt@hotmail.com
or call 269-367-4901
Viper 07-15-2008
My company own`s 3 squeeze pumps.
2-14m, and 1- 17 m, all 3 stage, mounted on Isuzu trucks, which are excellent on fuel.
Very easy to run and clean.
Their very popular in my area.
Advice: Keep the pinch tube well greased....
