mrmike36z | 05-03-2009 | comment profile send pm notify |
I have a grout job coming up that will need grout. I have a tkb 45 putz going through 2.5" hose. Is there any sack limitations or is just a 4000 grout good enough. This will be pumped really wet also. |
biged | 05-03-2009 | reply profile send pm notify |
If it really wet 3,000 will work,but 4,000 you want know you are pumping almost like butter. |
eugene | 05-04-2009 | reply profile send pm notify |
do not get 3000 lb really wet it will seperate, 4000 lb if its stacking up in the chute add some water but wait until its mixed. fibermesh is fine. i have a throdule servo on it because the driver will keep filling even though you stop pumping. the book says that the vibration will seperate the mud in two minutes. tkb-30 lots of power. |
Jake | 05-04-2009 | reply profile send pm notify |
you will be fine with 4000, if you are looking for a bag, I would say 6 to a 9 bag and you be fine. if its grout and its mixed you wont sep. but if you do I just stop the engine while your not pumping. you should be able to pump as wet as you want
crete | 05-04-2009 | reply profile send pm notify |
Do you have to prime your line with slisk pac or something? |
