Travelteck | 02-18-2010 | comment profile send pm notify |
B-alto made a post on my post ‘Prevent Power issues”, He brings up a good point I might have not stated clearly. In the concept of “preventative maintenance” this is not some thing to get into just before a job, I am thinking about rain out days, days with no jobs, or time when if you have the “Snap Oops!” its not a big panic to correct. Thus the term is “Preventative” not “destructive” Maintenance, but if you do find some thing like B-alto did he saved himself a huge issue down the line by looking for issues, so don’t be afraid to look but use understanding as to when, I do live by the old adage, Just before a job or on a job If it’s working DON’T MESS WITH IT. B-alto way to go finding an issue, Pray tell what was the symptom or problem that had you looking at the connection, did you have a power drop problem or just checking all the connections? |
b-alto | 02-18-2010 | reply profile send pm notify |
Thinking back, it was that the electronic malfunction light would come on when I was down the road a few miles. I noticed the hot wire was corroded as stated. There is a very fragile lobe on Mack alternators and its hard to get a back wrench behind it if at all possible. I ended up replacing the alternator, no it didn't solve the EM problem but like you said a good battery and alternator is a must. It was getting old any way. The E light still comes on sometimes and the code reads 3-4 injectors are bad. Mack said that couldn't be, they said the harness is probably dirty? Its hard to work on now in a snow bank but this spring I'll address it. |
Telealbelt | 02-18-2010 | reply profile send pm notify |
Trouble never happens when the weather is nice. Working on stuff in a snowbank sounds familiar. Alternators are expensive too. Replaced on both trucks after nine years. |
Justapumper | 02-24-2010 | reply profile send pm notify |
Tell me about it Tele. This year for myself and another operator it was batteries on the first really cold day. They were cranking the trucks up without a blip till that day then the next it was the screw you Im done working. On my rig the batteries were 7 years old so I guess we got our moneys worth out of them. |
b-alto | 02-24-2010 | reply profile send pm notify |
There's a guy in Bemidji, MN Terry's electric, that will rebuild an alternator for cheap like $50. This one he couldn't get the bearing off. He said one in a thousand get stuck. He does stock rebuilts though I think it was around $180 which is not bad. I'm not sure what Mack would want but I bet it is high. Terry's good, he'll rebuild while you wait. I bet you could even have one shipped. |
