some help please!!!!
danny16 08-27-2010
 hey everyone iv just started driving a new pump a 34m schwing just after some advice on how to get it to slew smothly. any advice would be much apriceated thanks. pump on.
rusty22 08-27-2010
 Practice lots of it.All pumps have their little quirks. When not pumping. You can swing it off to the side and play.Or do it in the yard.You might not get paid for it ,so what ! I spent hours doing it didn't bother me a bit.
danny16 08-27-2010
thanks rusty22 been trying that but dont seem to be geting any better and plus iv been on a putz m24 for 4 years maybe that why ?
bigstick 08-27-2010
When you move your joysticks look at the stack valves and make sure it is a porportional pump and not a black and white.
jj707 08-27-2010
Does it have a vector system ? If so you will need a service tech or software and a laptop there is a way to adjust the speeds and the proportional
TooTall 08-28-2010
Set up dead level, Relax and become one with your machine...
danny16 08-28-2010
thanks for all the advice and yes it is proportional so will check the valve block when go back to work tuesday. once again thanks.pump on.
boony 08-28-2010
if it has vector you can adjust the % by inserting a key into the vector.manual should explain it all if not get some one who has done it.just remember it will move differenetly full of crete and whether your full stik or not.manuel also suggests you operate on snail and just fold and unfold on rabbit.
getRdone 08-29-2010
Everybodys answers are good and remember when your laid out flat you can catch your load aka boom and it wil be smoother. ALmost like you were running a black and white or a crane. When you swing and then stop, get back in it again briefly. So when your booms about to swing back a little after you went one way with it you catch it. Pump ON
"MUDDY" 08-29-2010
i agree with you. by getting back into it this actually takes the little bit of slack between the ring gear and the slewing gear. sometimes you will see the boom bounce from side to side. it is as if it is bouncing back and forth on the two gears.
hunter 08-30-2010
read the tech manual, find out how to put the pump in teach mode, follow the insructions,
16 CELL 08-30-2010
I agree with the previous couple posts about catching and releasing the boom, one thing that can be also helpful is when trying to find the point of stick travel at which the boom actually begins to slew is to listen for when the hydraulics begin to "load up" which I notice just as the boom is about to begin slewing... obviously on a noisy sites this method is not going to be very useful, but on those pours that when you can clearly hear what the machine is doing I find it to be helpful.
jj707 08-30-2010
16 cell I find that method very useful on a putz but the hydraulics on a schwing, to me are a little harder to identify the loading until it starts moving, but that may just be my deaf ass, these mack fans are killing my hearing, but still a very good point.
pumpaholik 08-31-2010
hi danny16 u've just got 2 get use 2 it thats all it iz u'll find out wot it can and can't do every pumps different ive had the chance 2 op. many makes and model pumps u'll get it.
