| GPM1985 | 05-01-2025 | comment profile send pm notify |
I have started trying 5" hard sponge, ~5 gallons water, 6" soft sponge when sucking back on my 41M Alliance roll-and-fold, it does not have a ball stopper on the priming port. I am running into problems with either the first sponge entering the hopper or the second not getting all the way home. Company policy is one sponge/no water, but using water seems to be preferred based on what I'm reading and watching. Thoughts? |
| Todd | 05-05-2025 | reply profile send pm notify |
Sponge and Water Cleaning Methods for Boom PumpsIt sounds like you're trying to find the optimal clean-out method for your 41M Alliance roll-and-fold pump. Here are some thoughts based on industry experience: Regarding Your Current MethodUsing the 5" hard sponge + water + 6" soft sponge approach is actually a solid technique that many experienced operators prefer. However, since you're having issues:
Alternative MethodsWater Wash Method: As mentioned in the forums, many experienced operators prefer water washing:
Single Bucket Technique: This method is highly praised by experienced operators:
Company Policy ConsiderationsWhile your company policy is one sponge/no water, many operators find that using water makes the process more effective and can actually extend the life of your equipment by ensuring a more thorough cleaning. If you'd like to discuss this with your company, you might point out that proper water use can:
Would you like more specific troubleshooting for your current method, or information on how to implement one of these alternative approaches? This answer came from ConcretePumping.com AI |
| selina pump truck parts | 05-13-2025 | reply profile send pm notify |
Preparations before cleaning Timing: Clean immediately after pumping (before the concrete has solidified). Tools: High-pressure water gun, sponge ball (cleaning ball), sink or water collection container. 2. Cleaning steps Reverse pump back the residual concrete: First, the residual concrete in the pipeline is pumped back into the hopper through the "reverse pump" function of the pumping system. Rinse with a sponge ball and high-pressure water: Insert sponge balls at the end of the pipe (to prevent direct water erosion and damage to the pipe); Start the high-pressure water gun, inject water in the reverse direction along the pipeline for flushing, and use the water pressure to push out the remaining concrete. Key cleaning areas: Hopper and S valve: Manual flushing to prevent concrete from solidifying in the crevices; Hydraulic system: Only clean the exterior. Do not directly rinse the hydraulic components with water (to avoid water ingress failure). |
