squeeze valves
The Cat 09-18-2007
do any of you guys out there run a unit with a squeeze valve on the end hose.if so what do you think of them??
The Cat 09-18-2007
do you use a 5" hose or a 4"..over here in the uk the gangs always what the 4" on because its cleaner for them..
greedy 09-18-2007
just fitting squeeze valve to my 52 doing a bit at a time as we are busy had help from putzmeisters at chesterfield with wiring as my 52 is a generation 1 not a generation 2 which the kit is for hopefully will have it finished by the week end will let you know have you used it on a 4inch rubber yet  how are you getting on with your 63
why not 09-18-2007
Is it worth the price I have a price from con forms for 2k.
ruck 09-18-2007
Honest, I don,t like mine. I try  not to use it. It still leaks a little. Not a big fan of it.
The Cat 09-19-2007
hi.. i use a 4" end hose mostly..... really like it it just becomes a little bit of a pain when it comes to wash out with all the air pipes and clips every where..... mamaged to sort it out today altered the pipes and clips so hopfully a bit better from now on..as regarding the 63 it's brill... :-).. who`s 52 do you opperate??
greedy 09-19-2007
 i work for south coast concrete pumping have had 52 for nearly a year you can see the pictures i posted in the recent pictures and media and you might have seen me in the trucking magazine
