eugene | 03-01-2007 | comment profile send pm notify |
a cable is a back up for a radio get a remtron boss unit about $1200- i walk the hose when i prime, because once you are pluged the pump will still go and the pressure needle will tell you too late that you are in trouble. you still have to trace down the plug. my putz runs smooth so when i stop pumping the driver does not have a clue so then i have five inch slump over the rack and in the chute and maybe the street. so i put a syncro start with an auto relay and had to change my cable bracket, it cost me $100- and i get better fuel economy. manufactor specs calls for idle mode after two minutes of stop pumping so that you do not separate the water out. if you do a ten minute time out have the truck spin the barrel and maybe a one gallon spash on the fins. i have a 50 gallon AG tank about $100- on my one ton and go to the jobs dry and fill off a slow well so i do not have to wait 20 minutes to fill the hopper. i will fill the tank if it is a new constrution that does not have water. summer this is needed but winter you can by without. |
