steady flow
Slinger488 02-16-2011
Yes, I run a 93 meter Schwing with 11 1/2" boom pipe. It seems just as soon as I start to get a steady flow the redimix truck is empty,and if I turn it up too fast we loose the hose guy. Just last week we lost one, and ended up finding him in the next county.How can I speed it up but still slow it down ??
pumper chuck 02-16-2011
hell just pass around what your smoking and forget hose men
Vasa 02-16-2011
I had the same problem , I changed the pipe to 9,5" so now I have a steady flow + I could mount 1 more boom, less weight in the pipe . So now it has 7 boom-pieces with Y-folding, 107m.
Just goes to show you everything is bigger in KS. I'll try to get some pics but I dont know if I can find a 96 mm lens. I'll let the hose guy take pics on his way out
pumpslut 02-16-2011
lol
stink21 02-16-2011
try leaving the working side outriggers in, whats happening is there providing to much support an keeping the boom is a upright position also try not using any water in the primer the water is slicking the pipe up to much an causing the concrete to flow so much easier an with so little pressure it needs to have alot of resistance to where u have to turn it wide open an when u get it out the tip hose turn around an call your girlfriend an find a comfortable seat an enjoy the show..hope this helps you
Dipstick 02-16-2011
93m schwing with 11'' pipe.......Extra section up to 107m?? That must be strong stuff you've got there!! Funny :-)
52putz 02-17-2011
You need an 11 1/2" double 90.
duh.
AK1 02-17-2011
ok i know just how to solve this its not the double 90 you need the full rams curl in 11.5 but i think you should use pvc to make and you will ba able to add some more boom maybe make a 101 m hehehehehehe
Many 02-17-2011
A steady flow? mmm.After a 12 pack of bud and a couple shots.
Dipstick 02-17-2011
Replace one of the deck pipes for an endhose.. It will flex so the mud will get less grey down the way.. Works every time!!
