| thump | 02-24-2016 | comment profile send pm notify |
Been looking through the parts book for my schwing 39x 2525-5 and I'm not clear what is worn. Anyone here who has had this happen and how was the repair? |
| pudg2 | 02-24-2016 | reply profile send pm notify |
if its leaking oil out of it usually its because you have a seal leaking on a hydraulic pump, I deal with this pretty regular on my schwing pumps. |
| thump | 02-24-2016 | reply profile send pm notify |
thanks for the response guys. Looking in the parts book and not showing any seals listed, just the pumps themselves? |
| BCCP | 02-24-2016 | reply profile send pm notify |
You'll probably just have to call schwing and ask them for the hydraulic pump shaft seal. We just did it on one of our cifas and they don't break down the hydraulic pumps in the parts book on those either. You can probably find them way cheaper from a seal distributor, But then you'll have to take it off measure it and wait for it to get delivered. |
| gboom | 02-24-2016 | reply profile send pm notify |
Buy a shaft seal from Schwing, and before you put it in, get all numbers of the seal |
| The Punisher | 02-24-2016 | reply profile send pm notify |
2 things to check in case you already have not. It could be gear oil caused by two things. Breather could have a restriction creating heat build up which in turn creates pressure and out comes some gear oil. Or your airshift is leaking air into the gearbox which will do the same thing. Simple fixes |
| Schwing | 02-25-2016 | reply profile send pm notify |
Hi thump, Feel free to give us a call 888-SCHWING (724-9464) and as for service. We'll be happy to walk you through it. |
