swivel gasket tips...
16 CELL 09-14-2010
anyone have wanting to share tips/tricks for getting swivel gaskets to seal nicely and not leak. Seems like on all our 4 section Z booms the swivel gasket between section B and C has a tendency to leak. Any helpful info would be greatly appreciated.
pumpaholik 09-14-2010
Polyurethane gaskets they last for ever
any pump 2 09-14-2010
fill the in side of a standard seal with grease aswell as out side and use bolt on clamp if you have one,(hex key)or alan key as we call them in england
murf 09-14-2010
CF do some solid gaskets- last for ages
Dipstick 09-14-2010
For a quick cheap solution. Open the clamb, put some ductape around the gasket and close the clamb again. Maybe use a hammer ;-)
I've seen 2 different rubber gaskets. One with sharp edges on the outside (or on the 'top' if you like) one with a bit rounded edges. Make sure you have the one with the sharp edges.
ScottS 09-14-2010
Conforms has a great gasket for swivelss the part # is 529PO9346X. This is the best metric swivel I have seen. it is made of a little better rubber than the rest any question feel free to call me
eugene 09-14-2010
visqueen, paper anything to seal the air leak.
Travelteck 09-15-2010
First confirm the alignment on the pipeline joint is corect. If the pipeline is out of alignment the clamp and seal will wear out fast.
I got a sugestion from a student in a class, instead of filling the gasket with grease he fills his with silicone, it gets semi solid and wont wash out with the concrete so soon. He loved it.
