| Theo | 10-04-2009 | comment profile send pm notify |
Does anyone have a used teleteach bettery they would like to sell? Even if the batteries don"t hold charge that would be ok. My remote keeps losing its memory on the right slewing function. |
| poohbear | 10-04-2009 | reply profile send pm notify |
do you set the memory after you teach the function?I also have another way to adjust it.E mail me @ gregneumeier@yahoo.com |
| PUMBO | 10-04-2009 | reply profile send pm notify |
There should be 2 buttons inside the receiver where you can adjust the sensitivity without using the actual battery. |
| rich3317 | 10-08-2009 | reply profile send pm notify |
PUMBO , Is right, Putz won't tell most poeple about that way. Got to make that money lol. |
| Theo | 10-08-2009 | reply profile send pm notify |
I found the buttons in the reciever got the problem fixed thanks alot |
| Don | 10-09-2009 | reply profile send pm notify |
If it still doesn't retain memory, it could be a bad joystick or a bad output controller board. Call the factory Radio Repair Center for assistance, if the problem comes back. I'll bet Putzmeister doesn't broadcast about the receiver buttons because some operators will not leave anything adjustable alone. This leads to cracked PC boards, acid from skin oils eating components and other nasties. |
