| stimey | 12-05-2011 | comment profile send pm notify |
how would i drop a 60ft 5in pipe into a 45 degree angle pile without touching the rebar |
| Raymond | 12-05-2011 | reply profile send pm notify |
The crane that's lifting the pipe will do all of the lifting and dropping. You just want to make sure to have very clear communication and good pre-planning with the crane operator since you'll be attached to the pipe with a DE 5" hose. You're not going to be lifting the pipe with your boom alone, I would assume. |
| southtexas | 12-05-2011 | reply profile send pm notify |
First when you say "I" hope you do not mean your boom! But hear is how you do it, it worked good for me.First insert your pipe into the cage above ground.Then tie top of pipe to cage, let the crane do all the work. Use slick pipe no (clamps or rings welded )slick so it will not hang up on the way up doing multipal holes two pipes BUT BE CARFULL WHEN PUMPING THAT YOU ARE NOT LETTING THE CRANE TO SIDE LOAD YOUR BOOM PULLING PIPE OUT. PENDING THE ANGEL OF YOUR SET UP, PIPE IS ALLWAYS MOVINGIN TWO DIRECTIONS, THAT IS FROM EXPERIENCE. SOME CRANE OPERATORS ONLY WATCHING THEIR LINE NOT YOUR BOOM, SO BE IN CONTROL AS PIPE IS BEING MOVED OR IT COULD COST YOU $$$$$$$$$$$$ |
| stimey | 12-05-2011 | reply profile send pm notify |
we will be using a crane. inserting the pipe in the cage before is a good idea thanks |
| Step Brother | 12-06-2011 | reply profile send pm notify |
What I dont get, is why would you ever need a pile 60 feet at a 45 degee angle? Seems odd to a Florida boy |
| Beast | 12-09-2011 | reply profile send pm notify |
lots of bridges on the supports have vertical pilings and 45 degree pilings on the outer edges |
| kneerick | 12-10-2011 | reply profile send pm notify |
the crane needs to put it in the hole, |
