| sunmas | 04-07-2008 | comment profile send pm notify |
Has anyone ever experienced this before Changed hydraulic filter in tank and also the high pressure filter for the boom on a 900 32 meter. set out the outriggers and raised the boom then activated the pump and nothing happened. Agitators are functioning but the materials cylinders won't cycle. Any ideas?? |
| Phill | 04-07-2008 | reply profile send pm notify |
Is the Forward Neutral Reverse hand lever moving? |
| sunmas | 04-07-2008 | reply profile send pm notify |
Yep everything seems to be normal levers do function but nothing happens |
| Many | 04-07-2008 | reply profile send pm notify |
mmmmmm. e-stops,older ones boom would work but pump wouldn't. splined shaft for pumps. or http://www.schwingservice.com/user/login.php |
