38zman
04-16-2008 |
Hi I was wondering do any of you use such a device for testing the thickness of the boom pipe and elbows and if so are they reliable and accurate. Now the other thing is which one is a good portable I have been searching the internet and it seems there are a few out there but I have no idea which portable unit would be best to buy so any info that you can pass on would be great.
Todd
04-16-2008 |
reply
I wish we had one sponsoring this site, i would send you right to them but i dont even know who sells them. If you get a list of who sells them let me know ok i will call them and see if any of them want to sponsor this site
Thanks for the post.
Bob
04-16-2008 |
reply
38zman
I bet that if you call ConForms and Acme America you will have your answer.
cifa36z
04-16-2008 |
reply
testing the pipes with a hammer is still the best way from what im told big company in these parts bought 3 of them not worth the time good for mixers not for pipe you cant get a reading near the clamps or brackets where u need it most
Bob
04-16-2008 |
reply
Ultrasonic Wall Thickness Gauges
We offer a complete line of Portable Hand-Held Ultrasonic Wall Thickness Gauges, including an Intrinsically Safe Thickness Gauge, and Steel Calibration Blocks.
Low Cost |
TI-25LT |
- Factory set to measure steel or any other single material of your choice
- Range: 0.040 - 6.000" (1.00 - 150.0 mm)
- Resolution: 0.004" (0.04 mm)
- Impact-resistant and environmentally sealed for trouble-free operation under the toughest field conditions
- Free NIST Calibration certificate included
- 5-Year Warranty
- Easy upgrade to full TI-25M functionality (see below)
More information |
Standard |
TI-40N |
- Extremely compact & lightweight
- Range: 0.040 - 8.000" (1.00 - 200.0 mm)
- Resolution: 0.001" (0.01 mm)
- Selectable Units - inches or mm
- Built-in calibration test plate
- Quick display update with last reading retained on the display
More information |
Industrial |
TI-25M |
- Can be used in Single Thickness Reading mode, or in Scan mode, where the probe is dragged over a large measuring area and records the minimum thickness
- Range: 0.025 - 6.000" (0.60 - 150.0 mm)
- Resolution of 0.001 inch (0.01 mm)
- Special purpose probes are offered for a variety of applications, including underwater surveying
- 5-Year Warranty
More information |
Data Logging & RS-232 |
TI-25DL |
- Memory for 1000 data points in up to 10 batches
- RS-232C Serial output for downloading stored data to a printer or computer
- 5-Year Warranty
More information |
Thru-Paint |
TI-25M-MMX |
- Measuring range in pulse-echo mode: 0.040 - 6.000" (1.00 - 152.4 mm)
- Measuring range in echo-echo mode: 0.100 - 5.000" (2.54 - 127.0mm)
- When in echo-echo mode, the gauge automatically eliminates any paint or coating from the thickness measurement
- Can be used in Single Thickness Reading mode or in Scan mode
- 5-Year Warranty
More information |
Thru-Paint & Data Logging |
TI-25DL-MMX |
- Provides built-in memory for 1000 data values in 10 batches and is supplied with a Windows compatible data transfer program and serial cable
- Ranges are the same as the TI-25M-MMX above
- 5-Year Warranty
More information |
Precision |
TI-007 |
- Range: 0.0060 - 1.000" (0.15 - 25.4 mm)
- Resolution: 0.0001" (0.001 mm)
- Can be used in Single Thickness Reading mode and three alternative modes, Scan, Differential and Alarm
- 5-Year Warranty
More information |
Precision & Data Logging |
TI-007DL |
- 5-Year Warranty
More information |
Intrinsically Safe |
TI-1071 |
- Measuring Ranges:
TI-1071: 0.048 - 10.00" (1.2 - 250.0 mm) TI-1071-TW: 0.030 - 1.000" (0.7 - 25.0 mm) TI-1071-HW: 0.160 - 16.00" (5.0 - 400.0 mm)
- Selectable Units of inch or mm
- Accuracy ± 0,05 mm
- Limit value guides and monitoring
- Adjustable sensitivity
- Ex designation: Ex II 2 (1) G EEx ia IIC T4
More information |
Steel Test Block |
SB-4 / SB-4L |
- Precision Machined and Finished
- Includes NIST Report and Test Data
- Wooden Storage Box Optional
More information | | | |
Bob
04-16-2008 |
reply
I am sort of simple minded.
When I want something that has to do with pipe, clamps, hoses I call ConForms FIRST. So when I read a post such as this; I can not imagine that before posting, he hasn't all ready spoken to them.
This webpage has all the cool options on it. It has all price ranges on it. Lots of good specs. You can get a feel for the device you are looking for.
Then, after you have seen the options; you call ConForms and buy one from them.
It is only logical.
38zman
04-17-2008 |
reply
Thanks for the info and I was on the Con Forms web site and could not find ultra sonics anywhere as for tapping pipe with a hammer that is not allways accurate In the past I was doing a tap test on the boom pipe and it all sounded good but when doing a closer inspection I found a piece that was as thin as a piece of toilet paper and for the heck of it I hit it with a ball point pen and it went through....lol
