Ultrasonic thickness guage for pump lines
cp 07-16-2012
Our ultra sonic thickness guage just died. Im wondering where is a good place to find a new one thats not so terribly expensive. Any advice would be appreciated. Thanks!
Yuri 07-16-2012
Sorry Im not able to give you any advise, but I just wonder: which was the model of the gauge you used to check the pipes thickness? Were the measurements reliable?
cp 07-16-2012
Not sure the brand of my old guage, there are no markings on it, and it is fairly old. It did seem to do the job. If a pipe wall was getting thin, it worked well enough to identify it.
Pumper_eh 07-16-2012
Check with Keith from Alliance @ 1.888.870.0908
Yuri 07-16-2012
Thank you for advise!
Tom @ Irving Eqt 07-17-2012
You can try this website: www.ultrasonic-thicknessgauges.com
or just google ultrasonic thickness gauges & you'll have more options than carter has liver pills
pump wrench 07-18-2012
talk to fred at Pioneer 678-370-0000. i use the one that will read thru paint . Made by Defelsko. it is very accurate. price was not bad.
Tom @ Irving Eqt 07-19-2012
All will read 'thru' the paint but the problem is, that paint thickness is added to the total wall thickness.  This may only be a few mm's but wall thickness readings need to be fairly precise as there's not much of a difference in getting a few more yards (or meters) & blowing tubes.
