| GWR | 04-08-2016 | comment profile send pm notify |
Wat seems to be the best type of paint used for totally repainting the boom? Thanks. |
| orygun | 04-08-2016 | reply profile send pm notify |
b a s f is a good equipment paint like for the pipe. acrylic is one shot durable stuff. DuPont is nice for base coat, clear coat to give it a shine if you have a pretty color scheme. |
| b-alto | 04-11-2016 | reply profile send pm notify |
I would use an equipment level paint like AUE 300 you can buy it by the gallon and add a quart of hardner. It sticks well, and is cheap (150 a gallon) so you can use plenty. You need to give it a heavy final coat as to build up a gloss. It wears ok and can be re painted where as Emron can't . If you sand and paint over an existing paint job you don't need primer other wise prime it well with an epoxie primer. |
