updating remote
jd 11-26-2006
has anyone ever changed remote and transmitter on a putz I run  a32 meter and company has purchased the universal trans and remote box hoe hard is it to hook up  preseantly have remote with 3 joy sticks
redneckpumper 11-26-2006
if you got a pump you want to make work good just call concord and buy the stackvalve and proportional remote and hook em up. it will b like you got a new boom.
i sez concord just cuz it r cheaper than from putz and it r the same stuff
rcv1973 11-26-2006
It should be as simple as mounting the receiver, setting the dip switches so that the transmitter and receiver communicate and plugging in the harness.  Worse case you may have make your own harness going from the receiver to the controller.  If thats the case it should come with a wiring diagram, cable and connectors.  Crimp or solder the terminals on the indiv. wires then use the wiring diagram to place the correct terminal in the corresponding socket.  Use an OHM meter to verify the correct placement and recheck after the harness is complete.  If it doesn't work check continuity again.  I have made dozens of harnesses and had to change things on more than one occation.
