kid | 04-29-2014 | comment profile send pm notify |
Can anyone give me step by step instructions for calibrating a vector remote? Any help would be great thanks. |
kid | 04-29-2014 | reply profile send pm notify |
Yes and yes. |
Thanks a lot. I will give it a try
gboom | 04-29-2014 | reply profile send pm notify |
to adjust each section, you hold the reset button, and then you go into the function you want to adjust. Then you use throttle up and down to adjust, make sure you are in rabbit mode; |
bisley57 | 04-30-2014 | reply profile send pm notify |
yes.and.....snail mode for minimum setting-when joy stick initially activates rabbit mode for maximum setting-or full amount that joystick will travel |
service1 | 04-30-2014 | reply profile send pm notify |
We have 4 technical reps in our call center and an electronic repair tech in our radio repair room that can give you instruction on this. Please feel fre to call any one of them between the hours of 8:00 and 5:00 CST Jeff Popa Technical Service Manager and Spare Parts Specialist Off – 651/429/0999 X 213 Direct – 651/653/4213 Cell – 612/845/6981 jpopa@schwing.com |
