cifa k 35 | 02-16-2011 | comment profile send pm notify |
www.youtube.com/watch?v=5eDoEQly-pE |
cifa k 35 | 02-16-2011 | reply profile send pm notify |
www.youtube.com/watch?v=alNef44C8EI |
Todd | 02-16-2011 | reply profile send pm notify |
http://www.youtube.com/watch?v=5eDoEQly-pE http://www.youtube.com/watch?v=alNef44C8EI
for some reason this message board only like internet explorer and if you use chrome or some of the others it just will not post links. |
Hello Todd, before I could put the link now no more : (
biged | 02-16-2011 | reply profile send pm notify |
I didn't want to start a new topic, what cause's the squeeling sound coming from the switch over cylinder on the front of the S-tube. |
stink21 | 02-16-2011 | reply profile send pm notify |
more than likely its the mudcups or the s-tube needs some grease..bad part about a cifa is if u run cifa cups then i have to grease them everyday an it doesnt take long to get them to squeal i use to put dawn dish soap in my box to help provide some lube so it woudnt do it so bad |
mudcup | 02-18-2011 | reply profile send pm notify |
For the CIFA'S if you put slik pack in the water box that will lube up your mudcups That's one of the gr8 things about putz they got a drip system for the cylinders never makes a sound |
cifa k 35 | 02-21-2011 | reply profile send pm notify |
CIFA has an automatic spray on the pumping pistons ... (Droplets of oil in the water box) what you hear and only engine noise .... |
