MVCP | 12-01-2013 | comment profile send pm notify |
I read a post here about adding a electric hot water heater element to the water tank on a pump to heat water. Anyone done this? Did you use a power inverter to run the element? Can the same thing be done with the hydraulic tank? Dangerous to have the element in the oil? Welding the bung to the tank might be a problem. Thoughts? |
biged | 12-02-2013 | reply profile send pm notify |
I hook mine up to shop power at night and up plug in the morning,I have had one for 5 years now,just be sure you fill the tank before you plug it in don't you will fry the element. |
PEAGRAVEL PRO | 12-03-2013 | reply profile send pm notify |
biged havent seen you on here in a while how are things going for you? |
biged | 12-03-2013 | reply profile send pm notify |
I doing good I look and read this site every dsy,I don't type much unless I can help someone,Todd I see the snow flakes a falling, from Texas to Kentucky may get hit with and ice storm Friday I hope not. |
dlee7729 | 12-04-2013 | reply profile send pm notify |
Tap into the engine cooling system for free heat . |
