water tank rusting
nzpump 01-10-2009
Can anyone suggest a way to stop the inside of the water tank from rusting too much.
Bob 01-11-2009
Replace the rust pot with a plastic tank
Tiago40m 01-11-2009
Drain all the water out of the tank.
Fill it up again with antirust paint, and then drain it again. You will get every single spot, and it wont ever rust again.
cifa36z 01-12-2009
you can use zink like they use on boats marine supply stores sell them we have ones that are like a half inch threaded plug replaceable zink rods
Vasa 01-12-2009
Use them and fix them when the rust have eaten a hole in the steelplate...And when it is no more steel to weld in do like the Indians ! Buy a new one ! ;-)
pudg 01-12-2009
go aluminum or plastic if you replace if not keep patching,until you have to get a new one if its a putz and its a newer truck they may help you out with one, 2 of our trucks the tanks were cracking due to no shock absorbers under the tanks I dont know if this is the case with you but if its on a boom its something you may want to look at
Dipstick 06-06-2010
Good question. And what to do when you drive a JMBH 40m with x frame and both the rear ourtriggers are watertanks and they rust like H*ll. Everytime i open the tap and let some water run out it just rust. Big bits of metal/rust. Don't think i'm gona wait till there's a hole in them. (or replace with plastic :-o) The zink sounds like a good plan. But does that help when its already rusting so much??? My outriggers are just disapearing right now !!!
