Water Tanks
Russ 04-02-2007
I have a question about water tanks. Why are all water tanks on new pumps not pre-lined? They seem to rust through fairly quickly. Just seems strange that they would not use a thick lightweight polymer liner to prevent corrosion.
Bob 04-02-2007
Russ,
If you have a pump with a rusted out water tank just throw it away. The plastic tanks are the answer. You are right when you say the metal ones are no good. And BTW, I don't believe that the outrigger tanks have a lining, they are just thicker metal and have not decayed...... yet.
OneHit 04-03-2007
Where I work our 05 Schwing 34x Came with a huge Polymere or some kind of heavyDuty Plastic tank In Place of the old steel Tank , Just has a metal guard & looks just like old tanks
Many 04-03-2007
Yes the plastics are coming around.They are cheaper to make.If one looks at it there is a basic model and everything beyond that you pay for.
zxazxa 04-03-2007
i"m anxious to see in 5/10 or even 15 years what those who have the "outrigger tanks" will do?? does they gonna change the outrigger itself$$$$$$ or just welding and welding again??
personally im sceptic about the idea of the water tanks in the outrigger..i prefer far more a "classic" water tank
JohnThomas 04-03-2007
What pumps have water tanks in the outrigger??
Bigstickman 04-08-2007
most putz pumps have outrigger tanks as well as the older schwing 52m
Russ 04-08-2007
I utilize one outrigger for additional fuel storage. However I am not inclined to use the other for additional water storage. I would hate for that one to rust through. I drive a new 2006 model 36z and the water tank has already rusted through. Just frustrated to have problems this early into the usage of the pump.
gill 12-13-1901
irun a 06 38z putz i use one outrigger for water &the other for fuel it helps with stability as it acts as counterweight, we put some treatment filters in the water tank riggr t hel with rust
