what is compensation pipe
| salvis | 10-25-2012 | comment profile send pm notify |
What is compensation pipe ? I found it in http://www.concretepump.com.au/Pipes_Hoses/2480_2_GB_BP.pdf Why is it alternating length ? Thank you for advice. |
| CaSsE | 10-25-2012 | reply profile send pm notify |
Every pump got 1 piece of pipe which is measured while building the whole delivery line. It´s needed because the tolarances of every pipe add up; normally this compensation pipe varys within 50mm in one Pumptype. |
| Tom @ Irving Eqt | 10-26-2012 | reply profile send pm notify |
AKA 'make-up pipe'. It's what's left over after you've stuffed all the 3-meter pipe into a boom section you can fit. |
| salvis | 10-31-2012 | reply profile send pm notify |
Thank you for information, now i understand. |
