What kind of no stick are you guys using?
Vitulla 02-11-2010
Got a sample of stop stick from putz, was wondering alternative products in the market. I know many use hydraulic oil, but as funny as it sounds, I would like it to be a little cleaner and a little more environmentally friendly. I am in Canada if that makes a difference, since some products cannot make it up here due to custom regulations. Thanks!
happy jack 02-11-2010
Talk to the local residential wall guys and ask them what they use, it's all pretty much the same,Expensive! I use hydraulic, I suppose you could lube it up in Crisco. That would be good and green. Or mount a pressure washer on it and just forget about the oil all together.
16 CELL 02-11-2010
Vegetable oil works great!
pump wrench 02-12-2010
i seen several products used one customer uses pledge gets it in 5 gallon pails works very well. another customer uses animal lard this smells terrible and draws bee's but it does work. water soulable oils i feel do not work that well wash of to easy pump in the rain or snow the oil is gone. good luck finding what makes you happy
pudg 02-12-2010
Romix is the best I have used its environmentally safe and it is awesome lasts all day in 95-100 degree heat, it is fairly expensive though ranging from 8-10 US dollars per gallon.
Tracy 02-12-2010
I agree with 16 Cell Vegtable oil, but keep it in your cab in the winter!
crete 02-12-2010
Pudge are you using Romix backset? Or a different Romix product? I love the backset for cleaning concrete build up but never really used it foe a realese agent. If that's what you are using I will give it a try
                                                   Thanks Terry
crete 02-12-2010
Oops didn't spell check.
greenguy 02-12-2010
The romix products are also available in Canada.  www.fleetclean.ca.  Romix released backset platinum at the WOC this year.  Now can be diluted up to 6:1 to keep the cost down.
Romix's Body Guard should work too, but have never tried it.  I'll put it on the to-do list.
All our guys use hydraulic oil.
Telealbelt 02-12-2010
I use Backset and oil it up with WD 40 and oil mixed.
crete 02-12-2010
I am also a wall contractor so I always have a tote of reg. form release but it just hit me that the backset might work a little better. Still waiting to hear if any guys use just backset before pouring. I run a telebelt and all is well with form oil but sometimes you miss a spot or two and then try to get it cleaned off the next time (pia)
dlee7729 02-12-2010
In the winter nothing. hot water gets it all off. summer i use form oil.
greenguy 02-12-2010
Hey Crete,
I'd also be interested to hear from guys that actually use back set.
Its not really intended for that use as its a dissolver, not an anti-stick agent.  It does leave a slimy film on the truck though which would prevent sticking.
For those of you with dark coloured hoppers, it will leave a white residue when it dries that's a result of the sugar cane extract that it contains.  It'll wash off with water though.
pumper22 02-13-2010
Techniguard, just started using it, works great.
pudg 02-15-2010
the romix i am using isnt a backset its some type of mineral oil.
