Wide open!! look at her go!!
Frogburner 04-16-2013
  Now that I got your attention, whats the most yards an hour you have ever pumped and what size cylinders do you have..
biged 04-16-2013
That to personal about what size I have.
xforce1 04-17-2013
We ran 190 per hour with a 39 meter schwing with a 2023 system and 9" cylinders about 6 months ago. We out ran the mixers once each hour during the pour which was 580 yards
Mister_Perkins 04-17-2013
275 yards in 1 hour , with telebelt Sealed
Mr.HighRise 04-17-2013
average about 180-190 an hour on low side/rod side on a matt pour last sept. and with the same pump did 115 an an hour on the high side/piston side 38 stories up all with my 06' 39 schwing 2023-5 w/ 9" cup.....love the m-rock fine spline!!!!!
sgt580 04-17-2013
I pump a 39m Schwing also, 9" cyl M style rock valve. Do you get horrible boom surge pumping at high RPM and full flow?? I cant turn my pump control knob on the remote above 4 with the boom stretched out, it will surge up/down over 5-6ft.
Mister_Perkins 04-18-2013
check your back out riggers. they are probably floating. also check your soft switch make sure Its set to normal and not pressure control
igo 04-18-2013
Most ever is 210 per hour. But I have 11" cylinders on an old 2003 20 cell Putz. Cant realy control the ol" girl if ya turner up any higher. That is also 6" concrete probly a 4000 psi 70% sand 30% rock ( Cream of Rock Soup). Like pumpin butter.
Beast 04-19-2013
got 220 yph for 4 hrs on a 38m 20 cell putzmeister , 11 inch barrels, that was on a 4 ft deep 5000 yard foundation , 2 pumps 13 hrs to pump it.
