| PourItOut | 09-08-2009 | comment profile send pm notify |
1975 lbs washed river rock- 1000 lbs natural sand 611 lbs of cement no flyash no air entrainment |
| pudg | 09-08-2009 | reply profile send pm notify |
It should ,it maybe a little rocky but I think it should go , maybe go up on the sand some but I would give it a shot. |
| rick5z | 09-08-2009 | reply profile send pm notify |
seems like alot of stone (about 100 lbs too much ) 1850 to 1900 lbs per yard depending on cement, i think your rollin the dice. let us know what happens |
| 52putz | 09-08-2009 | reply profile send pm notify |
Looks like gravy to me. Washed river rock, bout 6 1/2 sack mix...stick it in and break it off! |
| green gold | 09-08-2009 | reply profile send pm notify |
what psi strength will that mix give? |
| PourItOut | 09-08-2009 | reply profile send pm notify |
With that much stone, probably a 4000psi or better |
| Many | 09-08-2009 | reply profile send pm notify |
Now I know why sheep shake in wyoming,sounds scary to me.You didn't mention pump,line used.Sorry but these things just rattle my cage,watch for flashing.It's just a coarse mix to me,if in doubt test pour that crap. |
| b-alto | 09-08-2009 | reply profile send pm notify |
No it won't, I've been there done that. Too much rock, 1875 on rock is about the limit for me and we have great dense rock. I have been sent pea rock mix with those amounts and it wouldn't even pump pasted the turret. It was designed for tail gate only. But good luck. If you have too (like I did once send it back and add sand and cement) . Then it pumped. Once on a deck pour they sent that mud with 150' of 4" system. 80 yds. We got it pumped but had to send one truck back. Beat the crap out of my poor pump pushing 200 bar all day. |
I did suggest a test run on the mix,,, if it does pump, going 5" line |
is it linepumping or boom pumping ? I took it as goin thru the boom 4" that would be tough and that much pea gravel would not but river rock 3/4 to 1" it should go thru a boom with a s-tube or rock valve. |
and with that much rock and that much cement its probably a 5-6000 psi mix |
| typesdubs | 09-08-2009 | reply profile send pm notify |
Hope you have a Schwing |
Now that I think about it. It probably will pump through a boom with 3/4" rock, being its a 6 bag mix. Make sure your systems tight no loosing grout through the cutting ring. |
| murf | 09-08-2009 | reply profile send pm notify |
Its not far off the old proportional mixes we used to do over here, 1:2:4 was a good basic cheap mix that pumped , depends alot on the quality of the sand. Maybe a little extra splash of aqua may help it along! |
also is the gravel graded or single size? |
| peter pumper | 09-08-2009 | reply profile send pm notify |
if it is gap graded it wont pump |
| Many | 09-09-2009 | reply profile send pm notify |
I trust you will let us know the outcome,some varied opinions on this on.Personally I feel it's harsh and if it's a spec job (slump) it could make it worse. Oh,watch out for that salesman with the bucket of super Pee Pee. |
| pumper chuck | 09-09-2009 | reply profile send pm notify |
sounds to me like an all nighter.geting paid by the hour i hope.fill the cooler with plenty of water/gatoraid or what ever can help keep you hydrated.and dont forget lunch and dinner those long days suck without nurishment.a good blow out cap and pig/godevel can be a life saver.good luck.NO GUTS NO GLORY,right? |
