Bob | 11-07-2007 | comment profile send pm notify |
For those of you that live in climates that tend to be REAL COLD in the winter; I have a safety related tip. When you are insulating your boom pipes; please do it with a material that does not absorb any water. Neoprene is a good product for this application. When I worked in the mountains of Colorado I always had to insulate the boom pipe. To remember my initial attempts at this is, in retrospect, funny. I used a sort of fiberglass-looking material that, when washed or snowed on, ended up weighing more than the boom. What a big mistake! This ended up being redone and wrapped in duct tape. It did work a little better, but still looked like s**t. The end all answer turned out to be a black (to absorb the heat of the sun) neoprene product that if taken care of would last several seasons. So it is one of those: Please do as I say not as I did... deals. Todays modern lightweight booms do not need to be over loaded to be properly insulated. ;~) |
Herbie | 11-07-2007 | reply profile send pm notify |
Other than protecting the pipe from the wind, what other precautions should be done for the winter, should you drain the water tank or just the wash hose, etc? Thanks |
